Starting issue
the problem started a couple months ago when my area was hit with a cold snap. 6 degree weather, quite unusual in olympia. at first i though it was the normal starter solenoid sticking. i had to click the key a few times before it would turn over. there would be times when i would have to hit the starter with a wrench, and then it would fire right up. now that the weather has warmed up, the problem persists. except i dont think its the starter sticking, because it doesnt click. i have to hold the key in the start position for anywhere from 2 to as long as 5 or 6 seconds, and then it turns over. anyone have any idea what could be causing this?
there is a round contact surface on the starter for when it spins it maintains electrical continuity, what happens is as you use starters that can get burns and corrosion in it. You can pull the starter and try to clean it (on the inside) or you replace it. That’s kinda what this sounds like, or it could just be a typical grounding issue such as these tegs have all kinds of strange phantom stuff that happens when grounds are improper. :slight_smile:
