steering still bad after alignment
i would go with a camber kit. at least your tires would wear evenly.
yeah, i probably will, but first i want to make sure this is normal wear stuff and not something bent…any idea how I can find out? I’d hate to spend money on a camber kit only to have something else about to go…
take it to a front end specialist or someone who specializes in suspension work. most of the time it’s a free estimate.
Originally posted by SOL1D
i got stocks and when i got new tires, i started feeling like it would jerk barely but it would jerk a litle to left or right, sometimes, im guessing it’s new tires with new grip so it’s gripping everthing on the road, little dips or imperfections in the road
ditto. makes sense tho, since my tires are much stiffer. holes, uneven pavement… if i wasnt holding onto the wheel i’d probably swerve off the road. otherwise it holds pretty straight…
what size are your tires and did you get an alignment camber kit yet? i wonder how normal this is and how imperative it is to get these… i will eventually of course…
Heh, these guys i took it to are the local suspension specilaists :slight_smile: I should probably look for another shop, though.
seriously, does this this much negative camber for a 1.8" drop on 205/50/15 tires sound remotely normal?
