Stock Timming Specs?????
:confused: does anyone know what the stock specs for the timming on a 91 rs???
16deg. BTDC at 750RPM plus/minus 50RPM.
Regards,
Oz
Originally posted by The_Oz
[B]16deg. BTDC at 750RPM plus/minus 50RPM.
Regards,
Oz [/B]
technically its an interval. so 16 deg +/- 2 deg. So anywhere in between 14-18deg btdc and you’re ok. however going as high at as 18 may cause detonation depending on the gas you’re running.
THANKS 4 THE INFO,FELLAS…:cool:
SUGGESTIONS ON WHAT OCTANE TO USE???
http://www.g2ic.com/forums/showthread.php?s=&threadid=28668&highlight=octane
I suggest 89 octane on a stock 91 B18A RS. The reason being is that over the years, there is a good possibility that the piston collected some carbon, varnish, etc. This thin layer of crud increases your compression ratio slightly. I suggest running a simple compression test. Stock 91 B18A RS should be around 184psi.
Regards,
Oz
P.S. Watch the CAPS please :slight_smile:
