I purchased a front and rear strut tower bar from Pilot Motorsports (Carbon Fiber); they are both sweet. Anyway, according to the posts, the Pilot bars are supposed to fit with no problem. I can’t get it to fit. What to do? BTW, I have a 91 GS Teg…Thanks in advance!
91 GS means you probably have ABS right?
yes, all GS models have abs.
skpdat: most likely the pilot bars you got are different. their “carbon fiber” bars are probably a different shape from the normal aluminum ones. If it doesn’t fit…then it doesn’t fit there isn’t anything you can do but get a new bar that will fit or ditch the abs…i’ll let you determine which is easier.
I have the carbon fiber strut bar from Pilot Motorsports. Anyhow, it fits. What you need to do is look at the ABS unit, you should see a black metal piece that wraps around it and holds the wires on it. Take those wires off of that bracket and take the bracket off. You should know what to do from there.
