My friend has a '92 GS and there is an odd sound coming from the pass. front suspension. It has gradualy gotten worse during the past two months.
I am not a Honda/Acura guy so I need some help here. The car has 140K on it. Do you think it a bushing that is making the sounds or do you think it is more than that…like maybe the entire strut/spring needs replaced?
Can you guys point me to any good sites (other than this one ) that I could get some info from?
Originally posted by BigDaddyCW
[B]My friend has a '92 GS and there is an odd sound coming from the pass. front suspension. It has gradualy gotten worse during the past two months.
Thanks!
Carl
1995 Jetta GLX S/C [/B]
It could be a variety of things. Be a little more specific with the sound. Is it a clunk? A constant rattling? or…ya know…something along the lines of that…
But our tegs are known for a squeak and clunk sound in the rear. I personally think it has something to do with the rear trailing arm.
It is more like a slight squeak whenever you hit a bump in the road. It is most def. not a clunk or rattling. It is also on the front pass. side not the rear. I was told that the car also seems to sag a bit in the front right too.
The car will also make the sound if you push down on the front end and make the car move up and down a bit.
If the car is sagging in the right front suspernsion, it’s most likely a bad spring. Check the spring for any cracks or any pieces that may have broken off. Like all Hondas, tegs are known for having spring problems…
I was thinking that it was the spring but wanted to see what you guys thought. If you haven’t already figured out I am a dubber and didn’t know if there was something that might be a chronic problem that I might overlook.
My friend is not looking to mod the car, just looking to get good replacement parts…or performace parts with a minimal drop.
Can anyone give me some sites and parts that I should look for?
If the springs were to be changed to say the H&R’s. Would new struts/shocks also be needed seeing the car has so many miles? Or could they hold off on struts/shocks for a bit until they get more money?
There are people on here who do it, and don’t seem to mind, but i’ve been in cars with springs/no shocks, and when the stock shocks go out in a year, it just sucks. Very bouncy. These were new Honda’s mind you, not one with 130,000.
It is my car that is sagging… Do you think that it could be a bad bushing or is it definitely a shock or spring? How would I tell if it were a shock that was going bad versus a spring or vice versa? And (since I am kind of short on money) if I only get springs like the ones with only a .75" drop, will this hurt anything other than the stock shocks since I am not buying new shocks at the same time? Thanks for the help!
IF IT IS SAGGING, DEFINATLY A SPRING. THESE THINGS ARE NOTORIOUS FOR SPING PROBLEMS. I HAD TO REPLACE ONE ON THE PASSINGER SIDE(FRONT END). MINE IS STARTING TO CLUNCK UP THERE AGAIN WHEN I GO OVER A BUMP. NOT A BUSHING OR A SHOCK.
