Suspension Sounds???
The drivers side front suspension makes a strange clicking / thudding / Squeaking sounds and shakes. This only happens when i take off from a stop and sometimes when just driving along, Usually on the motor way ( 100-110 Kms / 3100-3200 RPM) It gets louder and faster the more i build up speed. It does not do it when i turn. It eventually goes away when i reach about 70kms.
Also the car will sometimes stall when it has been turned off and restarted when it has been warmed up. The car will run for a few seconds then the revs will drop and will turn off. It will start fine if i leave it for about 5 mins. This only occurs when the engine is warmed up and not cold.
http://www.g2ic.com/forums/search.php?
“warm trouble starting”
“balljoints”
that oughta start you out. :up:
