Suspension Upgrade...?
I’m ready to buy the parts I want for my suspension but I want to know what else you think I’ll need. I need to be able to raise the rear of the car a bit because the 225/50/15 tires I have on there rub with the current suspension (H&R sport springs and KYB dampers) The list is short so far:
ES master bushing kit
Blox spherical trailing arm bushings
either k sport coilovers or koni/gc . . .
what do you think? I know everyone or at least most of you will say go with koni/gc but… can anyone give me firsthand experience with both? That would be awesome. And spring rates, I am thinking 12k f/10k r it is not my daily driver so not too worried about really stiff suspension. Also what else should I consider? I’m thinking brakes (rotors, pads, and lines) but not too sure yet.
the spherical RTAs will be a little harsh with the ES poly bushings, id say go for OEM/Mugen ones as they are perfectly fitted (not that youre going to have fitment issues with the blox one but there is something to be said for OEM fitment/comfort)
i dont have any more input other than that. good luck
e: just re-read and noticed you arent worried about ride quality. spherical bushings are the shit and if you dont care about the harshness then go for it.
thats like comparing crap to a diamond
Ground Control FTW
buy some blown konis rebuild them to “race spec”
then hit up www.nwp4life.com for the $315 shipped any rate
ground controls and you should have a sick set up
as far as the RTA bushing, easiest to replace is OEM
for the ES/BLOX you have to completely burn the OEM bushing and keep the “shell”
then press the ES/BLOX bushing into the shell
Thanks for the input guys. Pressing the RTAs in shouldnt be a problem I have a press at work I can use actually for all the bushings if need be. I’ve pretty much decided on the koni/gc set up but not sure what spring rates to get… I am thinking 12k f/10k r … Not a daily driver so I am not too worried about those rates. Anyone have any advice on spring rates?
well konis are good to handle about 500-550 lbs spring rates
thats about a 9k Spring rate, so your 12k spring rate might be too much for those konis
just buy some blown ones and rebuild them to be badass lol
If you’re running OTS koni’s I’d start with 8-10k F / 6-10k R. Bias just depends on what you’re looking for. It’s generally best to start w/ a lower spring rate, learn how it handles then work your way up. Plus, like Leo said, when you hit about 10k you’re at the limit for the OTS Koni’s. Use that rate or up to that rate, then when you’ve tracked the car and realize you need a higher spring rate you can revalve them to the RACE spec and be able to run higher rates.
My opinion after having the ES Black RTABs installed is that its more costly to manipulate the ES bushings to fit and burn out the old bushing than it is to just buy the Mugen OEM replacements and call it a day. The guys at Meineke spent over 2 hours trying to get the Black ES RTABs to fit with the original pin and shell. I love the ES RTABs and they feel great but I ended up spending more in labor for the install than I did for the actual parts. After watching them do it and fight with the new insert, I was happy I made the choice to have a shop do the work (no press available and I really didn’t want to start burning chunks of rubber in my garage to remove the old bushing).
I always read that Konis are so great but both sets I have owned in the past have failed. I have had 2 sets of Konis fail on me within 6 months of ownership. One insert sheared off at the arm when I installed a set on my BMW M3 (quality defect) and I had a front pair of Konis completely blow out within a year on my Civic. The civic was lowered on Tein S-techs and the M3 was on its stock springs. This was all during normal driving. Koni gave me free replacements in both cases but they did not cover the cost of reinstalling so I had to foot the bill. I will never buy a Koni product again.
This car will be mostly driven on the street and possibly on the track on weekends. I am not too sure about the front/rear bias in spring rates, I know that a stiffer rear helps the car rotate but more easily allows oversteer and a stiffer front will understeer like it should stock. Is this info correct? This is why I want the front to be stiffer I would like to maintain some of the stock handling characteristics. After reading what Colin said I think I will go with 10k f/8k r. I just hope the front being at 10k will not damage the konis…
Also, dumb question: what does OTS stand for? I searched a bit but was unable to find the answer.
That’s a pretty big generalization, but in general, yes it is true. There are just a lot of other factors such as tires, tire pressures, sway bars, suspension travel, alignment settings…etc Just because you have a front bias setup does not mean you will understeer and vice versa.
It’s typically a smart idea to start out w/ a car which will understeer a bit when pushed, that way you can learn the car and it’s handling in a safer, more predictable and manageable way. Once you get more comfortable you can move to a more aggressive setup. That’s what’s nice about coilovers, you can easily make those changes by swapping springs front to back or just buying new springs.
When setup properly 10k/8k can be very neutral, I ran this setup for a handful of years and it wasn’t sketchy at all (imo).
10k is pretty much the top of the Koni’s, it may make them wear a bit faster but the main thing is that you’ll be reaching their limit of damping, so at that point you’re approaching a setup where you’re under-damped. I wouldn’t worry about this for your situation. Fact of the matter is there’s all sorts of theoretical talk on msg boards but 99% of us won’t be able to know or take advantage of these small differences. Drive the car, learn the car, and learn how to drive in general. As you do this it’ll become apparent what needs improvement on your car to make it work better for YOU. It’s the learning process that is important. You can take a novice with a pro setup and they’ll be slow as all hell compared to a seasoned driver with stock suspension. Start with a smart setup, quality parts, with the intention of making changes as you progress YOUR ability - car should match the driver.
[QUOTE=triskpin;2111350]
Also, dumb question: what does OTS stand for? I searched a bit but was unable to find the answer.[/QUOTE]
OTS = Off The Shelf
It means the standard Konis. That term is used because you can have custom Koni’s built and other manufacturers also sell modified Koni’s (e.g. True Choice).
Thanks Colin. I will continue to research and experiment with my car to get it how I want it. I’ve been reading about the konis a lot, I think I will start with 10k/8k. Again, thank you all for your input.
Good Luck, and most importantly - Have Fun!
(btw, don’t ignore alignment settings, so definitely look into that, as well as tire pressures. After you get everything installed you should pick alignment settings that are performance oriented, maybe not full race but definitely more aggressive than stock. And after you get it all put together you can start messing with tire pressures and shock adjustments to “tune” it to your liking as well as just experiment and learn)
[QUOTE=buckwilly;2111312]My opinion after having the ES Black RTABs installed is that its more costly to manipulate the ES bushings to fit and burn out the old bushing than it is to just buy the Mugen OEM replacements and call it a day. The guys at Meineke spent over 2 hours trying to get the Black ES RTABs to fit with the original pin and shell. I love the ES RTABs and they feel great but I ended up spending more in labor for the install than I did for the actual parts. After watching them do it and fight with the new insert, I was happy I made the choice to have a shop do the work (no press available and I really didn’t want to start burning chunks of rubber in my garage to remove the old bushing).
I always read that Konis are so great but both sets I have owned in the past have failed. I have had 2 sets of Konis fail on me within 6 months of ownership. One insert sheared off at the arm when I installed a set on my BMW M3 (quality defect) and I had a front pair of Konis completely blow out within a year on my Civic. The civic was lowered on Tein S-techs and the M3 was on its stock springs. This was all during normal driving. Koni gave me free replacements in both cases but they did not cover the cost of reinstalling so I had to foot the bill. I will never buy a Koni product again.[/QUOTE]
the shop just didn’t know how to install them. they are a lot easier and faster to install then the oem bushings if you follow the instructions that come with the bushings.
It was entertaining to watch either way. I never did them so I couldn’t dictate what was fast or slow in regards to the install.
