I’ve been researching and testing to figure out why my 92 RS won’t start for almost three weeks now (which is bad since it’s my daily driver) and I’m pretty sure I’ve narrowed it to the ECU, but I want to get some more expert opinions before I sink money into a new one.
Basically, the car was running great with no problems until three weeks ago. I drove to an appointment, and when I got in it to leave, the engine would just crank and it wouldn’t start. Verified no spark on any of the plugs, and had it towed home. I’ve replaced the ignition coil and the ICM and neither helped it. All fuses have been checked both visually and with a meter. The other strange thing is that the CEL comes on and stays on solid with no code when jumped.
I’ve gone through all the troubleshooting charts in the Helms manual and also tested the main relay. I checked both wires coming into the distributor with the meter… I get 12V coming in from the relay but nothing coming in from the ECU lead. All the tests on the troubleshooting charts pass, and I’ve gotten to the box that says “Replace ECU with known good unit and retest” on every chart. Does this seem likely, or is there something else I have overlooked?
Also, if it is the ECU, is there someplace I can find a compatibility matrix with which ones will work in my car so I know what to buy? Thanks.
This happened to me by saying ingnition coil you mean the “igniter” inside the distributor? Because that is what failed on me and it was a relitively easy fix
Both the ignition coil and the ignitor (ICM) have been replaced. No dice.
Dang did you try the starter relay its under the dash and controls spark and fuel.
Starter relay tested OK as well.
Damn did you replace the rotor and cap? Did you replace the whole distributor?
Swap entire distributor first with known working one, then swap in another ECU with known working one.
One of them will undoubtedly show you where your problem is.
Its best to just keep a spare §§§§§ and ECU around for exactly this kind of situation.
If you have not had your ECU chipped or opened up for any reason its not likely that’s your problem (not impossible but unlikely) unless you suffer from the passenger side leak under the dash…That can mess the ECU and connections up pretty bad if left unattended.
I had an ECU that I had chipped go bad and kept blowing distributors…now I always keep one of each on hand for testing. Should be able to get one used on this site for $50. In the mean time try and borrow one from another G2IC’er in your area if you can.
x2 for swaping ECU.
My friend had the same problem where his car wouldn’t spark and he replaced the ignitor, coil, check the mfr, starter. He finally narrow it down to the ECU which for some reason got fried?
The MFR (Master Fuel Relay) under the dash? Its Brownish colored. Is that the relay you tested? Mine tested fine, but had a cold solder in it. 2 minutes of taking it apart, and resoldering it fixed mine. Again, it would test fine, make connections correctly, I believe it was just not passing enough amps. I also cleaned the relay’s contacts with emery cloth. They were a little dirty, but obviously made a connection.
I’m not saying you didn’t test it correctly, but if you only tested continuity, it could pass, but fail on the amperage part.
I went through 4 ICU’s in ~4 months before I fixed the MFR. This ICU was fine for over a year until the distributor’s bearings went south and I replaced it with a new one.
I had the same problem a few years ago and it was the coil, surprised that didn’t fix yours too, sounds exactly the same
I have had a coil do this also, though like I said above, I have had it happen with the ICU and MFR too. All act the same, all will throw the same codes (if it throws a code at all). My coil died after I changed the oil. Pulled it in the garage, changed the oil, pulled it out of the garage. Realized I had left something in the house, turned the car off, got what I needed, car would not start. I had one ICU die at a stop light after driving for 20 minutes. Another ICU die after sitting over night, and the MFR died while driving. There is a reason I buy lifetime parts. I have replaced my ICU 4 times (not counting the full distributor), but only bought 1 ICU. Nice thing is, I have that ICU from the original distributor, and the ICU in the new distributor is lifetime too. I have a backup in the trunk in case something like this happens.
Same thing with the coil, wires, cap and rotor.
All lifetime warranty.
he said he’s getting 12v from the relay, none from pcm. i would test voltage at the pcm to confirm that it isn’t between the pcm and distributor
if the pcm is determined to be at fault, i believe any 92-93 integra non vtec should suffice
operator where u gettin all these lifetime warranties?
Autozone for the plug wires and icu. Distributor, cap and rotor, o’rileys. That’s the full distributor and cap and rotor. For the coil, I think Autozone. I would have to check my reciepts.
bah…You guys and you’re autozones
We don’t have those fancy stores up here.
