Ok so My car wobbles upon acceleration really bad. So a month ago I took it to an Acura/Honda specialist (they do all the the warranty service for the major Stealerships + regular mechanic work). Anyway they tell me I need the passenger side tie rod & drivers side boot and that I need it done asap, On the receipt they stamped car is unsafe to drive. They gave a price of $299 + tax. After seeing that price I left without getting it done. I’ve been driving with the wobble/shake since the day a brought it like 2 yrs ago.
Fast forward to now. I got my tax return and decided i'm gonna get this fixed. I return to the specialist askin for the price to get this fixed. Knowing the original price they told me the first time I just wanted to see what he'd say. Well the new price is $337+tax...:shock:
Now I’m confused, what could possibly warrant a price increase! So I leave and Buy the part myself from Delray Acura $65 and the Boot for $20 take it to a Regular Joe Shmoe mechanic(specializes in German car repair) and tell him i need my tie rod fixed and that I have the parts already what would the damages be. Without blinkin an eye he says $75 WOW!! Now Im thinkin thats too cheap. What is a fair price to have these fixed?
P.S called the Acura specialist back and told him i have the parts now, what would the price be now. He sounded pissed that I brought it myself and said there would be no warranty if they installed it. Keep in mind he gets his parts from the same place i got mine from. Price would be $255+.
Sorry for makin this so long.
I am fully quallified mechanic with about 8 years nearly 9 years under my belt ive worked on french, german, korean, japanese and honda cars, if you were to bring that car to me with the parts in hand i would be looking at charging you about €30-€35 to fit the parts and another €40 to do a wheel alingment,
as for the guy in the acura place, he would be pissed cause he could make about 20% on the price of the parts, it all adds up!
as for the warranty, acura would give you a certain amount on the parts (dont quote me on it usually about a year).
The price increase is BS. $299 is high enough, he must think you are desperate. Of course the guy is pissed you didn’t buy the part from him, he lost a way to profit. Its policy at many places not to warranty customer supplied parts, mostly to protect them. I recommend staying away.
The better option appears to be the other dude. $75 sounds very reasonable. It can be done in well under an hour. I could probably do both sides in an hour with air tools and a lift. Get an alignment done while you are at it, tie rods are critical in the toe angle of the front end.
I disagree with the acura places pricing for sure, not to mention the price change. Do you know if the $75 the other guy quoted you included an alignment? I would say labour you’d be about an hour so about $80 plus an alignment which is about another $80. So $75 is quite reasonable but that probably won’t include a wheel alignment. $255 definately sounds too high.
You could get it done at the german place and ask for an alignment also. If they don’t do alignments there you could always go elsewhere. I would highly recommend getting it done though, if you don’t it could wear your tires out pretty quickly.
around here an alignment on a regular car is 70 to 90 dollars if u are lowered beyond the alignment machines capability some shops wont even do it but the most they will charge is around 100 to 120.:rockon:
I had a local meineke install my tie rod ends that I purchased online. parts were cheap, under $30 with shipping for the tie rod ends. Meineke did the install an chared me $40 to install both sides and a $50 alignment.
Total cost was $138 with tax all said and done for parts and labor.
You are getting ripped off at the acura place. Tie rod and boot install should take an hour at the most for both sides per Meineke - $75 is right around the correct price for labor. Go to the German car guy!
Ok so I took my car to the German guy this mornin at 8am and he was done before 8:30. I’m very pleased with the work. He used some laser thingy to mark where the old tie rod was removed from and replaced the new one to the exact location of the old one so I don’t need a alignment. The old one shot to hell, I can’t believe I drove around so long with it that way. Anyway The shake/wobble upon acceleration is gone.
Thats good you got it done ok. Just be aware that just because he put the tie rods in the same spot doesn’t mean that the alignment was perfect before he started. If your steering wheel is straight then its probably pretty close. My advice to you would be if you have never had it aligned since you owned it, get it done.
