timing belt
how tight should the timing belt be? :hmm:
there is an autop tensioner… let the spring tensioner do its job
yea i did it how the manual says but it doesnt seem tight enough. I got all the slack on the tensioner side before i did it.
help
i need some advice on how much slack should be in the timing beld any help will be greatly Appreciated!!!
thanks :slight_smile:
how tight should it be… because i can twist the top of the belt +/- 40 degrees.
stiff on the right hand side, finger deflection on the left side.
