TO swap or hybrid !?
I have a '90 Ls db1 which sat for a long time. When it came out of the body shop it ran really poorly and to my surprise had two rocker arms jump off and rattle around in the valve cover. I replaced the cam and the rockers, then it happened again.
So I am asking what opinions there are out there about a swap or a possible ls/vtec . I am not sure if odb0 would be good with vtec, but at this point I am thinking new head for sure. At the same token a b18b is only about $500 shipped. In consideration of a tight budget, should I just swap in a new engine for this workhorse or replace the head ? I figure a head job will run about $500 in parts anyways. (timing belt, tensioner, water pump, gasket set, head)
Drop some real world knowledge on my ass for I have not been too active on this club in a couple of years.
if it costs the same, i’d go with the head. you’ll have the peace of mind that the t belt, HG and WP were done at least
How many miles does the motor in it have? How long do you plan on keeping the car? LS/V done right will cost over $2k, so I would say that’s out of the question.
