Tokico Adjustables and Ground Controls
I finally got the time to install my Tokico whites and got rid of the stock shocks and struts. The stock ones rode nice with the Ground Controls, but I bought the Tokico used so i mightest well switch them. After I had install them, [SIZE=“3”]I set the settings for the front at 2 and the rear at 3. I must say, it’s bouncy…more than the stock shocks[/SIZE]. Any opinions?
increase the dampening. ie turn up the stiffness on the shocks until it stops your going to have to play with it and test drive it until you find the best setting
I run mine on setting 1 (softest setting) for all four and it rides fine with Megan coilovers. I use the DA for daily driving…
sweet! After playing around with numerous combinations, I set all four to setting 1 (softest), and it rides good again. Thanks to all who have helped.
Hey buddy! Do you have any pictures of your car on that setup? What sort of spring rate are you on too? Sounds like the similar setup I have in mind for my 92 RS.
