I’ve got a 90 teg and my tranny needs to be swapped out… what are my options… i know swapping in a hydro tranny would be hell, so what trannies can i use from what car? Also I hear that my clutch is different than all other b-series cars? is that true?
the 88-91 Main Shafts are 25 spline. the 92+ are 26.
I would suggest a tranny out of a 92-93 GSR or the JDM equivalant. That would be a VTEC YS1. Be very careful because all DA 92-93 trannys have the YS1 Code but they aren’t all VTEC trannys… and i would also suggest getting the 5th gear swapped.
I would use the 5th gear out of a G3 GSR
Part number
Main Shaft Gear # 23461-P80-V00
Counter Shaft Gear # 23581-P80-V00
Lock Nut # 90202-ph8-000
Those part numbers will only work on a 92+ tranny and will require a 92-93 Clutch kit
you can also use
a1
J1
S1
Y1
Trannies they would need different 5th gear part numbers and a 90-91 Clutch Kit
HTH
HTH
good info. only one correction though. Where it says “92-93” clutch kit it should say “92+ b series clutch” most likely you’ll be ordering a 92-93 one…but really all 92-93 b series clutches are the same thing, so if you found a deal on one for a 98 gsr or something…its the same EXACT clutch.
sorry man but that is incorrect info…
when they went hydro the change the release bearing…
make sure you get a 92-93 clutch kit.
[B]sorry man but that is incorrect info…
make sure you get a 92-93 clutch kit. [/B]
that i didn’t know. but usually if you’re buying a clutch for a good deal its no longer the kit anyway. My point is that all 92+ b series clutch pressure plates and clutch disks are the same. notice how i didn’t say “kit” anyway.
actually now that i think of it… are you 100% sure you are correct about that bearing?
exedy organic clutch part numbers (courtesy www.clutchcityonline.com)
92-93: 08-800A
94-01: 08-800B
this would make you think that the clutches are different. However when i ordered a 92-93 GSR clutch from them i was sent a clutch with “08-800B” on the box (a 94+ clutch kit). The pressure plate, disk, flywheel bearing, and release bearing all fit perfectly.
Honda has a different part number for it. I guess i have never had them side by side.
Why risk it ??
just get a 92-93 and calll it a day. ![]()
The 92-up B-series pressure plates are the same/interchangeable. The Release/TO bearing although different on one end (the end that the hydraulic release arm snaps into) is the same where is pushes on the fingers. Colin is correct.
Thanks
Thanks A lot for the info guys!!! I appreciate it.
so you can use a 94+ kit on a 92-93 but you can’t use a 92-93 on a 94+ ?? because of the release bearing ??
