i have a 91 with a b20b in it put 1600 miles on it be4 my stock ls diff decide to commit suicide
i found a bought a gsr cable and new 92-93 clutch kit and put it all together
i upshifts great thru all gears but here is the problem downshifting into 3rd it just wont have it
u can rev up the motor and try to slip it in but no go the only way it goes into 3rd is to hit 2nd then back up to 3rd and that works sometimes
yes i have adjusted the cable
it is a brand new clutch,pp, and throwout bearing
any takers on what is causing this
could this have something to do with it
the shift linkage is alittle stiff (side to side) could this be fixed by getting a new shiftlinkage or is my clutch cable bad
also r the 90-91 axles different in size from the 92-93(using stock 91 axles)
my guess is maybe the syncros or something inside might be going bad, i dunno i’m no trans expert though
Im not to sure if i follwed your post correctly but did you get a gsr clutch cable?
I had the same thing in my tranny that the gears didnt want to shift so I ended up flushing the fluid out for new oem honda mtx fluid and it helped a lil…
And all 90-93 ls axles are the same, only difference is if you have ABS or non ABS. I have ABS and managed to get a buddy to hook me up with free LS axles, tuened out they wouldnt fit in the HUB so I just ended up getting ABS axles…
if all gears work upshit and downshift except third id assume it’s a synchro problem or a gear problem. especially if it didn’t do this with your old transmission assuming you didn’t change anything else. i have problems with third gear on my gsr ys1 also but mine is upshifting.
i would flush it and maybe use some synchromesh for like 4k miles and then switch back to the honda mtx
