Hey dont want to sound stupid but have u smelled the fluid is it transmission fluid or regular oil? If its oil it could be a rear main seal, and i had the same issue till i figured out i had been getting the wrong axle seal.
yea its tranny fluid…im going to try again…on jackstands ill let you guys know how it goes
so i may have found the problem…my axle keeps sepreating from the tranny…why?? i had it on jacks and watch it leak out of the axle…any help?
one of 3 problems,
the carrier bearing in the driveshaft (axle) is gone and causing the shaft to move in and out,
the gear box bolts are not tight and causing the box to move away from the engine,
the shaft finish could be damaged causing a leak, check for rust or pitting of the surface
changing clutch by myself at night. :bang:
there might be a crack somewhere hard to see
Did you fix it?
no still having the same problem
In the picture is that the halfshaft? or the axle? If it is ,may be bent or not bolted down properly. mybe even that metal ring cover
the halfshaft…im going to check it again after the rain stops…but i may have not tightened the bolts enough and i dont think its bent
how did it go?
well i removed the axle again…got a new seal still leaks…i read that it can leak from not putting the seal in with some kind of seal tool
anyone have any advise?
as long as you used something flat to press the seal in, that case is unlikely.
wierd issue man, try another half shaft and see what the results are
alright…ima pick up a new halfshaft this weekend…anyone in the NORCAL area want to help me figure this out?:umno:
ttt
bump
car too low= Tranny leak?
so ive been trying to find out the problem with my car for a while…so i took my car into a shop and they told me that my car is too low causing the axle to flex thus making my tranny fluid leak out of the driveshaft…is this possible?
ttt
ttt
ttt
