su[ fellow g2ers i have a 90ls and i am having trouble starting it recently. i mean it will start but it takes a while, sometimes i have to hold the key until it starts, sometimes i have to turn the key off and try it again it usually starts right up after i do that any suggestions on what could be my problem
your starter could be going. could be other thigns tho.
i was thinking that too but a friend told me to check the spark plugs will try that today see what happens
Change your spark plugs, cap & rotor and see if that helps. If that isnt it then it will probably be something like the coil or main fuel relay.
Later,
BR
you wold not believe this today i took my car in to get looked at and found out that the main fuel line was rotted through and that the fuel leak that i thought was so minor and so easy to fix turned out to be so major, but o still love my g2 peace ![]()
