turbo is in now what
Hi
I have a 90 4dr with a B16. just finished installing a greddy turbo kit with a TD04 turbo. I also front mount intercooler. I have not don anything to the fuel system yet. It also has the timing @ 12dgr.
? is
What do i have to do for fuel?
what should i get for the fuel system?
what should I set the timing @?
what should I to run 8PSI safely?
Any help would be great.
A fuel pressure regulator (FPR) will be needed. You can also get the apex-i v-afc to fine tune the fuel map. If you didn’t replace your injectors to larger ones that would be a good thing as well. I’m not incredibly knowlegable on this subject, but it should get you started.
your greddy kit didn’t come with any fuel solutions? if not, you’ll need an fmu & an inline fuel pump. injectors & a vafc are also smart options if money permits. or you could ditch the fmu all together & get a hondata/zdyne.
your timing is fine for an fmu setup. you can run stock base timing if you have a hondata/zdyne.
I think you should try the AFC Hack. You’ll need:
A’Pexi V-AFC
MSD BTM
Walbro 255 ltr/hr in-tank fuel pump
4 450cc DSM injectors from 91-99 Talons, Eclipses, and Lasers
No need for an FMU, check valves or missing link.
i have a set of DSM injectors if you need em. I just have to find them.
Thx for all the help
I think you should do way more research…If your going into the project blind and not knowing what you need for fuel management? Not tryin to be a jackass…
You’ll need an FMU and a inline fuel pump minimum.
ok i forgot to say that i had fmu & inline pump just wanted to know what else i should do. just want to run a 2 stage boost. 5psi & then go to 8psi & have it run safe i also am puting in 100octaine gas that i can buy here.
