turn signal doesnt work
well today i tried to tuck in my wires from the passanger seide.every thing was good unitl i everuthing back and tried my lights.the side one doesnt turn and my turn signal neither.then the bulb for the headlight on the driver side doesnt turn on.i checked the fuses and they seem good.any suggestions on wat i did wrong or might of happened??
maybe the wire is grounding out?! perhaps the bulb itself?
i checked the bulb to the other side and it works.
is it just the passenger side?
yea.
to make it quick i would just check it with a multi meter.
the bulb plug??
check it from the fuse… make sure its getting power and if so check it from the wires on the bulb plug… if its getting power at the fuse then its defintely between that and the bulb plug… (although you kinda know that already it eliminates a few other things)
ooo.okay.well i checked the fuses and they are fine.so i gues i’ll check the plug.
fix it
i fixed my turn signal.it was the ground wire that was bad.
