uca hitting top of strut tower
hey guys i have a really slammed da, my drivers side has alot more camber than my passenger side, ive broken my lower ball joint 2 times on the drivers side already. i notice that wen my car is sittin i see that the uca is like 3 millimeters away from hitting the top. how do i fix that by not raising up the car?. if i were to put a camber kit the screws at the top will be hittin even more.
heres a picture of the car. im currently runnin 15x8’s right now though.
Some people cut a hole in the shock tower. But most just raise the car.
if i were to cut a hole wont it ruin the durability of the strut tower?
I would think it would make it weaker. But i hear you can cut it an the reinforce it buy welding some metal around it or some thing not to sure didnt really look in to this. As my front mud flaps are about 1inch off the ground an i dont hit like you are
hmmm. is there a reason why i keep breaking my lower balljoint on the drivers side?
not sure maybe something is bent an is making it bind an the ball joint is the weak link?
i dunno. it has never been hit before anywhere. could it just get bent over time?
something might have got bent when you hit a pot hole? it just an idea on were to look maybe you should try to get an aliment then you might get an idea if some thing is bent (maybe)l
You must mow through tires eh? I love the look though haha… What brand of ball joint are you using? It’s possible someone forgot to take out the snap ring for the lower balljoint before pressing it out and bent your spindle…
lol yeah i already flipped the tires outside to the inside cuz of all the camber. i installed the balljoints myself. its properly installed so i dunno. theres alot of stress on the lower balljoint cuz of all the camber
at least you wont bounce off the bumpstops.
but im always afraid of hittin a turn, if my baljoint snaps thenn im screwedd
There’s really no reason why your balljoints are broken when you’re slammed unless you’re using really cheap ball joints or something on that side is bent…
I’m slammed 3+ inches and never had a problem after switching form broken OEM balljoints to MOOG balljoints.
As for your UCA’s hitting the top… like others said, cut a hole on the top so the screws clear or just simply raise it a bit.
You can also go back to oem UCA and just make sure you get an alignment and set your toe at zero… that way even with camber… you won’t go through tires as much if your toe is set to zero…
how about those camber kits that bolt onto your oem uca? it just adjusts the arm back n forth are those any good?
they sit between the UCA and the frame. if your UCAs are anywhere close to touching the frame now, they will be even closer with those in, the OEM shock tower has reliefs built into it so the UCA can have some room to not bottom out. if you go moving the UCA outwards, itll impact the shock tower more easily.
stop trying for cheap fixes, investigate why your car eats ball joints and youll probably save yourself a lot of headaches in the future, you might even solve the UCA issue if an arm or two are slightly bent.
I’ve seen people cut a whole in the top of there strut tower and make a metal box and then welded that to the top to give them loads of clearence. I wish i had a picture.
i am going to try doing the alignment and see if anything is bend then il go from there i guess
