You guys need to come up with a better way to mount the top bolt. Threading into sheetmetal is a bad idea, your seatbelt will fail in a accident. You should weld a nut in, or put one in from behind, somehow.
I welded a nut to a piece of steel with a hole in it where a bolt could pass through and welded that to the b-pillar(with the nut on the inside). Unfortunately, I don’t have any pics of it.
I’m gonna try and remember to take some pics when I install mine… but at the rate I’m going, its going to be a LONG while until I actually get around to doing the install. :mad:
