Vortech fmu and aftermarket injectors
Could i use a Vortech Fmu and aftermarket injectors with check valves, and run more than 6 psi because of the injectors? I know it sounds risky, but with the fmu and the stock injectors, all you have to worry about are the stock injectors failing…and if i had aftermarket ones…say 450cc would they be able to handle the pressure?
you need to take the fmu off and get some type of fuel management. you can’t run an fmu and larger injecters because it is going to dump entirely to much fuel and cause your car to run like complete ass.
