VSS sensor with p28 ecu in 93 integra
Im planing to use a chipped p28 ecu on my 0bd1 integra… but i have a question about the vss( vehicle speed sensor) since the cable tranny dont utilize an electronic vss, will i get an engine code for vss? i think i would… and would the ecu go on limp mode or anything or make the car run weird? any ways around this so i wont get a code… i hate engine codes. or would i have to buy a electronic vss and just run a wire to the ecu/wireharness? all i know that the cable vss is manual and has oil lines going through them does the electronic vss have oilines going through the vss and way around this not to get an engine code?
I’m using a p28 and no code on my LS-V
Ken
Originally posted by Riceman
[B]I’m using a p28 and no code on my LS-V
Ken [/B]
what set up is your lsvtec and do you have a b16 trans or vtec gearing or ever ran your car tell me your setup care to share?
