washer fluid
Is there a way to direct the spray of the windshield fluid when it comes out? Or is there a way to have it spray harder? Yeah don’t have a sick mind…this does sound BAD tho!
Y2Ken
For awhile I hooked up my own little sprayer in the back of my car near the license plate to fend off those tail-gaters. Used it a couple times and havent used it for awhile now.
how did you hook that up??
and I’m pretty sure you can adjust where it sprays on the windshield, but to get more pressure I’m not sure how.
To adjust them I just stuck a pin or somethnig into where it sprays out an move it around…
Also…my passenger side doesn’t spray as high or as much water as dow the driver’s side. Which is a good thing…but I’d prefer if they both were the same? Any way to fix this?
Y2Ken
go out an stick a pin or something small enough into where the washer fluid gets sprayed out and adjust it… spray… and keep repeating till you get it to spray where you want!!
Serial One:
So should that little ball that’s in there move aroudn freely? Cause mn’e spretty tight…I’m scared of breaking something actually…
y2ken
Just remember when adjusting them that at highway speeds the spray wont go as high on the windshield. So adjust the a little high while setting still and you should be right on.
ya it’ll be little stiff… but it will move…
as 93Teg44444 said adjust them alittle higher for when you are on the highway cause the wind will push the spray lower on the windshield
HTH
