right now i have some JG1001’s i like them, but i’d like to go with a lopier cam. i was thinking about 404’s but noticed they have a lot of overlap. anyone know of some good nitrous cams that still make good power off the gas??? here’s my setup if that helps:
JG p&p’d head
JG throttle body
PR3 B16a pistons
knife edged crank
PYR ECU
JDM y1 vtec tranny
AEM FPR
ACT xtreme clutch w/ 6 puck race disc
and last but definitely not least:
NX 100 shot wet kit.
You’re throwing a 100 shot on a b16 without building up the bottom end??? I’d spend the money on beefing up your motor before I put cams in or you won’t have one to worry about.
no actually, it’s a B18a. and yes i’m doing it without building up the bottom end. well, unless you count a block guard, and block girdle building it up. I’ve been spraying a 100 shot almost daily for the past 2 years, and just now have i been getting a noticeable loss of compression. but no big deal, the motor is coming out this weekend for a full blueprint and rebuild. and yes I’m doing it all myself. except for the machine work, i don’t have the equipment to do it.
