Well thanks to chris for the program! Once i changed the plugs and installed a new distributor the car fired right up and idled better than it did NA. Ok heres the problem… I have a .5 spring in my tial wastegate but im only seeing 5psi on the gauge…So i decide to install this Manual boost controller…“big mistake i think” So since the car was secure and jacked and braced up i decided to quickly run through the gears. Around second gear and as the car was going into boost… ALL this white smoke start coming out…it was like Knight Rider for all you old heads and KIT hitting the smoke screeen button. SO I checked the coolant level and color, oil and pulled the plugs to see if anything is messed up. Results the coolant is GREEN, the Oil is fine and the Plugs are dry.
Fast forward 2 today i start the car and No smoke so i drive it work and then drive home at a light i notice some minor smoke coming from the front of the car but not from the back…damn i know that was alot but until i get a compression test im just trying to figure what the hell all that smoke was.
I almost forgot this happened…my friend was talking to this girl in her car so as im running through gears and smoke screenin the parking lot i notice that ALL the white smoke got into her new town car.
She was cool about it and I felt like the biggest ass… but my man got her number while her car aired out so everything worked out for the best. :giggle:
To me it soudns liek you ahd the car jacked up on stands and you were running through the gears? what??? :manual:
Could just be too rich. How white is the smoke?
Get her tuned
isnt black smoke fuel and white smoke coolant?
whats the smoke smell like? (usually u can tell if its fuel/oil/coolant) r u sure its white n not blue? is your turbo water cooled? do u have ne coolant links. more info is needed
this was the first time since i drove it that this white smoke came pouring out.
Maybe over the weekend i’ll re-check everything but it drives and feels really good! Chris I might have a few more guys sending you their ECu’s one drive in my car and they became believers!
Nice…hopefully I can make it down to one of the Maryland meets this summer
do you or can u tune on spot if u come? If so come on DOWN!!!
Its possible, we can talk as things get closer.
