Whats the best coilover kit for our 90-93 tegs?
Whats the best rear LCA’s for our 90-93 tegs?
Best bang for buck?
Also what is on your car and how do you like it? thanks.
Best bang for buck?
You’re going to hear alot of people say that the best bang for the buck suspension setup with adjustability is a Koni and Ground Control setup. It’s not a full Coilover setup but if you read through this forum and others you will hear the same.
Also what is your budget? Best bang for the dollar might still be out of your range. We’re talking $800-1000 for the Koni/GC setup.
imo Best bang for your buck suspension upgrade would be to replace your old worn out bushings
Second would be aforementioned koni/GC’s
Third would be upgraded sway bars
aftermarket LCA’s offer minimal performance increases and are mainly just for looks/and maybe added adjustability
a Simple wheel alignment can also make a world of difference if it hasn’t been done recently
No such thing as the best because everyone will have their own opinion. This has been asked at least 50 times on this site. I rock the Koni/GC setup and love it. I have a project and will probably put the same on it.
the best is 5000$+. forget what the best is. what’s your budget and what are you looking for from your suspension? what kind of driving do you do?
i have koni/gc with prothane bushings and etc. love it.
Does the GC/Koni setup really run $800+?
I bought my Skunk2 Pro-C full coilover setup for less than $600 and have been nothing but happy with it. I get compliments all the time on how smooth it feels. Just the right amount of stiffness for daily driving, though I dont know the spring rates…
[QUOTE=wise_old_dragon;2151752]imo Best bang for your buck suspension upgrade would be to replace your old worn out bushings
a Simple wheel alignment can also make a world of difference if it hasn’t been done recently[/QUOTE]
This is nearly EXACTLY what my response was going to be. Bushings should be your priority. Can’t go wrong w/ Koni/GC, you’d be hard pressed to find anything that will match the quality and performance for that price. LCA’s are a waste of your money unless you’re in search of bling or you’ve done almost everything else possible to the car. And an alignment is crucial!
Unified112: The koni’s run about ~$400-$500 and the coilovers run ~$280-$300. I would be extremely surprised if the Skunk2’s were even close in quality or performance when compared to the Koni/GC combo - but I can’t say for sure cause I’ve never tried them. If you’re looking for performance, then “smooth” shouldn’t be the compliments you’re fishing for. If you want “smooth” then your priorities are probably more with comfort and looks than performance.
IMO the best part about the Koni’s is that they can be rebuilt. Buy them now when you’re first getting into modding your DA, then in 2-3yrs when you’re ready to start racing or ready for some more serious track events, just get them rebuilt, maybe to RACE spec. If you do that you’ll save a ton of money over buying something now to start with and then a different, more race spec, setup later. And the best thing about the GC’s is that they are made specifically to fit the Koni’s, so you’re not using something as a spacer between your shock and threaded collar.
Brand New or Used? Are you sure they’re Pro-C and not the Pros-S?
Hah… good catch, yes I meant the Pro-S. I’m definitely not an early morning thinker. And as far as people calling the ride “smooth” I mean feedback wise.
Compared to my buddies ghetto DropZone setup he had, the handling and feedback are more smooth… his handling was sloppy/sloshy. His choice of the word ‘smooth’ is probably incorrect, its more crisp/tight and doesn’t bounce for a mile after hitting a small bump.
The S2 is the first decent set of coilovers I’ve had… coming from a DC that had oem struts and Eibach lowering springs. In comparison to the spring/sleeve setups that my friends have chosen, the S2 is worlds different.
But yes I’ve heard for a long time that the Koni/GC setup is a great combo as well.
[QUOTE=unified112;2152098]Hah… good catch, yes I meant the Pro-S. I’m definitely not an early morning thinker. And as far as people calling the ride “smooth” I mean feedback wise.
But yes I’ve heard for a long time that the Koni/GC setup is a great combo as well.[/QUOTE]
What shocks are your friends using? The differences you’re talking about have zero to do with the spring, and 100% to do with the shock valving/condition and possibly shock length as well. There is absolutely nothing wrong with a sleeve type coilover setup as long as you’re using the proper shock design.
My buddy was using stock struts with a coil/sleeve. And the other was using a full setup made by DropZone. Using their strut, coil, sleeve, bumpstop, etc.
The main thing I disliked about the DropZones was that when entering a steep driveway, the rear-inner tire would sometimes lift off the ground… then when settling back down you could hear the sleeve/coil assembly shifting around. I’ve yet to hear sounds like this from a shock that has a threaded body. Though maybe is the GC and Koni setup is made to go togehter like you mentioned, there may not be the issue with slop as described above…
I’m not trying to start a debate, or say that my setup is better than the GC/Koni setup… but for the price, I’m having a hard time wanting to buy a sleeve/coil setup over the setup that I currently have.
[QUOTE=unified112;2152137]My buddy was using stock struts with a coil/sleeve. And the other was using a full setup made by DropZone. Using their strut, coil, sleeve, bumpstop, etc.
I’m not trying to start a debate, or say that my setup is better than the GC/Koni setup… but for the price, I’m having a hard time wanting to buy a sleeve/coil setup over the setup that I currently have.[/QUOTE]
Not debating, just conversing. And I’m definitely not going to get behind dropzone shocks…
There’s nothing wrong with lifting a wheel, but it can be unnerving to have a spring come loose. Although it’s pretty much not a problem at all. It’s been happening on race cars for a long time, typically w/o any issues. Plus, it’s more of a strange situation like you mentioned (steep driveway) than in any important situation (i.e. high speed corner). Generally if you’re lifting wheel in a corner it will be because of a droop limiter on the shock in which case you probably aren’t creating a situation with a loose spring.
It’s really a balance, a traditional coilover system would be preferred, but in this case that decision would be form over function. As far as I know you cannot get a traditional coilover (threaded body, opposed to collars) system with the performance to match Koni/GC for the price. Even at a higher price point I was having a hard time finding a threaded body system to match Koni RACE shocks + GC’s. The PIC Select’s were a close second, but IMO they had yet to be proven on track. If I was making my decision now I’d have to do some more research cause I’ve heard really good things about the PIC’s.
Well I ask bcuz right now I have H&R “Race Mode” lowering springs on stock shocks and I find the front is not low enough but I like how the back sits. Surprisingly with stock shocks it’s smooth and handling is good enough for what I need it for (just daily driving). I do need to replace bushings as I’m pretty sure there shot it hits hard in the back on pot holes n big cracks (n where I live its every damn road) I don’t think it’s the shocks cuz there not bouncy or nething. I got the bushings for the bottom of the rear shock where it goes through the LCA should I replace all bushings in back, or you think replacing just those bushings would help a bit? I want to get new bolts cuz I know there going to snap or be stripped. Would a Honda dealership have them?
Has anyone heard of godspeed, k sport, NEX, function & form coilovers they seem to look like good quality coilovers with shocks and priced good under 700$ but i’ve only really heard of the F&F ones.
I would replace ALL your suspension bushings, not just the lower control arm shock bushings. OEM is your best option, but it’s quite expensive. I generally recommend the Energy Suspension Hyperflex kit in conjunction with some other parts
Front
Rear
Additionally you can get camber and toe kits for the rear which will give you new bushings. However I don’t consider these two arms to be as big of a deal. The ES kit doesn’t come w/ replacement bushings for them, the stock compensator arm is already adjustable for toe, and you can shim your stock UCA to adjust for camber… so I don’t see aftermarket pieces as a necessity.
[QUOTE=92hondaintegra;2152161]
I want to get new bolts cuz I know there going to snap or be stripped. Would a Honda dealership have them?[/quote]
Yes, you can buy new bolts from Honda. However I doubt you’re going to want to do that once you see the price. You can expect most of the larger bolts to retail for right around $10 each. If you want to replace All the major suspension bolts you’re looking at a bill well over $100.
Has anyone heard of godspeed, k sport, NEX, function & form coilovers they seem to look like good quality coilovers with shocks and priced good under 700$ but i’ve only really heard of the F&F ones.[/QUOTE]
I haven’t heard anything positive about any of those brands. I think the K sports and F&F have been getting better in quality, but if I were you I’d so some good research (searching, not asking) before committing to a purchase.
