I have an all stock 93 integra with a bad exhaust system and am looking for something quiet I have looked at getting an s2000 muffler and having the tubing bent at an exhaust shop but it would all be crush bends. I have also looked at the flowmaster exhaust which I like but its only 2” what is your opinions in this is 2” OK I have also noticed that most headers only have a 2” outlet so 2” all the way should be better that stock right?
2" from the header flange back is fine. The stock is either 2" or 1 7/8", its been so long since I had stock I can’t remember. I ripped it all out early on.
My first setup was a cheap header with a 2" outlet, 2" Cat, 2" mandrel bent mid pipe and a 2" Flowmaster rear section. It worked fine and was not loud enough to get me pulled over. It was definitely louder than stock though, especially at high rpms.
Keep in mind that the Flowmaster kit is an axle back, it starts at the right rear wheel so you will need a mid pipe to go along with it. I recommend against crush bent piping. Sure it will work but it will hold you back a bit if you are looking to make the most power possible.
Good luck.
flowmaster exhaust are not muffled with the fiberglass stuff on the inside. They are usually hollow with walls in it. I’ve never herd of anyone doing 2" piping as a catback, usually you would want to go with 2 1/4".
It dose not make any sense to have an exhaust larger than the outlet of your header I plan on getting a headman header cuz its cheep and I am replacing the rest of the exhaust so I might as well get a new header and O2 sensor. The outlet on the headman is 2” so going with a 2 ¼ at the rear dose not make any sense to me.
( Did you notice any power from your setup therealkroysc ? )
enjoy the top end with 2"
[QUOTE=joe383;2117005]
( Did you notice any power from your setup therealkroysc ? )[/QUOTE]
My original exhaust was rusty and missing a muffler. I drove it only a few times before I did the 2" system for $300 in parts with free (traded) labour. I was tight on cash at that time. I was happy with it being quieter than what I had before. It seemed to rev fine and I assume it made a bit more power than stock. To be perfectly honest I have never driven a completely stock B18A so I can not make a good comparison. I assume the header made more of a difference than the rest of the system.
At the time of my B18B swap I put in a Tri-Y header with 2.5" outlet, 2.5" hi flow cat and a 2 1/3" DNX Stainless catback. The new setup is MUCH better for power than the old one. It ended up costing more than twice the cost of the first one witch I sold to offset the cost. The kid I sold it to seemed happy with it, but then again he was 16 and stupid (he thought his car was actually fast, he ran a 16.5 in the 1/4 with his auto, what a douche).
if you dont mind a little more noise a header with a cat and muffler and 2 1/2" all the way through would be great. thats what i plan for mine
I am also looking at the Pace Setter monza exhaust 2 ¼” and looks like it will be a little quieter than the Flowmaster being that from the picture it has a pre silencer and it is a full cat back apposed to Flowmasters axle back system I just don’t like the big tip it has guess I can change that but I think this is what i am going to get instead. Honestly I am gong to run a resonated cat delete and try to weld the cats heat shield to it so it looks like it is still there I had one on my last civic with a header and loved it just a little tore on a cheep header that has an outlet larger than 2” now.
joe383: Please put a proper location in your profile per forum rules. Thanks!
I would reconsider, my brother had a pace setter monza exzaust and it rusted out after the first year and IMHO sounded realy ricey. If your planning on running a catdelete, it will be especialy loud.
Im sure you could do a custom 2 1/4 exaust with a pair of resonators and a good muffler for about the same price as that exaust.
My $.02
