what size wheels when you have turbo inside??
I was thinking of getting 16s just because they are cheaper than 17s,… the tires I mean.
I will be going turbo soon,… and my friend told me to get bigger wheels cause if i’m getting turbo, all that power will make my little 16" wheels spin the hell out of them,… what do you think???
Can 17’s with 215 tires fit without rubbing??? what offset??,…if they do fit in stock height,… then i’ll lower it untill the fender and the tire have like half an inch in between…
what do you guys think???
thanks.
huh? hopfully your 16’s will have the same diameter tire as you stock 14’s and so will the 17’s . . . . you could go with a greater diameter to stop wheel spin, but it will change the whole gearing and the speedo will read differently . . . . if you need to experiment with tire sizes check out my website:
http://nonsense.netfirms.com/tiresize.html
it’s like this
195/60-14 = 23.21"
195/55-15 = 23.44"
205/45-16 = 23.26"
205/40-17 = 23.46"
if you want a bigger diameter tire:
205/50-16 = 24.07"
205/45-17 = 24.26"
