What spark plugs??
What spark plugs do you guys use??
I have a 91RS and i think it needs a tune up so I just wanted to ask you guys what u guys use
Thanks for the help
NGK and don’t use anything else (ie. Bosch, Champion, etc.). They don’t come close to the quality. I’ve heard Denso are pretty good, but damn expensive and hard to find.
Regards,
Oz
Hes right, I work parts at are Honda dealer and NGK is affordable, and real good quality. The recommended plugs for B18A are not platinum so depending on what you wanna spend you might wanna move up to them but I would definately stay with NGK.
i too use NGK plugs…they are great:p
I regularly switch between NGK and Bosche Plat+4…I don’t know how you guys can tell the difference. They feel exactly the same.
I just purchased the Denso Iridium plugs and they work GREAT!!! I have upgraded my ignition to the MSD 6AL so I guess almost any plug would work fine. I used to use Bosch Platinum +4 but switched to Denso Iridiums just yesterday. Would definately recommend. The costed $10.99 each but that’s the cheapest I’ve found them ANYWHERE, including the internet.:defend:
OEM NGK! :up:
I use OEM NGK’s for the set of 4 it was under $10 Canadian at the dealer(cheaper then some of the parts stores).
