The outer trim of the door, there is a foam seal that seals out the elements. Well mine is leaking, and i want an OEM one to replace it, what is the name of the piece. Outer trim panel? I have no Friggin clue, can you help.
Weather stripping? Is that what you’re talking about?
I believe so, Dan. If you look right at the door. That trim that is atop, it’s kinda of a metal or plastic. As time goes by it will leak from age due to the mateial breaking down. I want to replace it so it’ll quit leaking on the passenger side and possiby blow up my computer.
