ok. i just got my new tires intalled and the guy at wal-mart looked at the tire wear on one of the front tires and said i need to get them aligned… i was wondering what some symptoms i would experience if i need a wheel alignment, if any… and if i really need all 4 wheels aligned… any comments or opinions would be helpful, thanks
negative camber, uneven wear, car pulls to one side, etc
easy, if your car was pulling (and still is) to one side over a distance of 150 mtr at around 40~60 mph, then it is your toe. If you have enven wear on the tyres (one side) and no pulling, then you have negative camber especially if you are lowered.
If u don’t get it fixed, your new tires will wear the same as the old!
wheel works promises (sp?) alignment for 1 year… go there once and take it back as much as you want
never heard of it… the cheapest place i found around here does it for $40… everyone else charged 60 or more
when i got mine aligned at pep boys, they said your warranty is voided if you do any suspension modifications =/
i’ll probably just get it done at the local place for $40
