Hi guys,
While I was searching and reserching, do you guys have a quick answer?
I have a 93 with a 94 GSR motor. Currently using a 93 alternator which needs replacing.
Should I just get this one rebuilt or should I get one for that year motor (94)?
Not exactly sure if it makes much of a difference.
Thank you.
I dont think the alternator matters… I know that the DA pulley is different from the DC pulley in a sense that the power-steering part is different. But if the DA alternator is installed and working correctly on a B18C motor, then they’re obviously interchangeable… so it wouldnt matter which one you use.
k thanks
Also note that after 94+ alternators as far as i know are 80amp while the 90-93 are 65amp or maybe the 90-91 are? I have a 91 and a 96 gsr this is how i compared the ratings as thats what i read or find, so someone chime in please i would like an upgrade too later if somehow it is interchangeable. Plugs maybe different on those 90-91? And I rather have an 80 amp then a 65amp rating anyway since i power alot of stuff anyway.
If the 90 fits fine with no issue go with that it should be cheaper,but as stated if the other has a higher amp and you have a system you might want the newer one.
