A COUPLE OF WEEKS AGO I POSTED HOW MY TRANNY WENT AND I GOT A B16A TRANNY INSTALLED. TRANNY IS GREAT, JUST ONE QIUCK QUESTION THOUGH. WHICH CLUTCH CABLE BRACKET SHOULD I USE. THE S1 BRACKET OR THE J1 BRACKET. IF ANY ONE HAS A POSSIBLE SOLUTION, IT WOULD BE HELPFUL. OH BTW I THINK THE ONLY REAL DIFFERENCE IN THE TWO IS THE ADJUSTING FACTOR FOR THE CLUTCH. I FORGOT WHICH BRACKET IS ON THE J1 TRANNY AT THE MOMENT BUT THE CLUTCH IS RIDING HIGH, AND THE CLUTCH IS CENTERFORCE D.F. AGAIN THANKS FELLAS
Do you still have your LS bracket? There shouldn’t be any difference between it and the JDM brackets? I’ve only seen a JDM S1 so I can’t say for sure.
YEAH I HAVE THE LS BRACKET. THE ONLY DIFFERENCE I HEARD WAS ADJUSTING THE CLUTCH. SUPPOSEDLY ONE OF THE BRACKETS WILL MAKE THE CLUTCH RIDE HIGH. I JUST CAN’T REMEMBER WHICH ONE AND IF THERE ARE ANY OTHER DIFFERENCES I SHOULD KNOW ABOUT. THANKS FOR THE HELP THOUGH.![]()
take caps lock off!!! its annoying and hard to read.
not sure about the clutch cable brackets, i thought they were the same. it wouldn’t be difficult to try both, or just use one and forget about it cause we know both work equally well.
