Alright guys here is the deal, before blowing my stock b18a I bought some eBay knock of poly mounts
buy only installed the drivers side mount and had no problems. So my motor blew and I did a b18b
swap utilizing the remaining 2 pos eBay poly mounts and I have broken 2 driver side axles already,
so my proposition is to get some good mount because these are messed up in some way shape or form.
Ok, so which mounts should I get… innovative, avid (aren’t they the same?), hassport, or should I just
get some stock rubber mounts and get a set of poly inserts? The car is mainly a daily but I might take
it to the track and I plan on boosting once I stop breaking axles. Any positive help will be much
appreciated.
I myself have the Hasports and love em… But my local builder vouches for Innovative and says they are nearly as good as the Hasport units. I would use either of those and feel perfectly comfortable with my decision.
cool thanks… one more thing… which type should I go for street(red) or the next one up? Which ones are you runnin
I’m running the Hasport street-rubber. My buddy had one step up from street Hasports in his EF, they were pretty damn stiff. I’ve been happy with mine so far, though the dash vibrates quite a bit more than it used to though lol. But that’s what happens when you get stiff mounts.
I think the street mounts were rated for like 400hp, the next step up was rated for like 600hp if I recall correctly.
i have all four innovative steel mounts in 75A (black) and they work real nice. i had the prothane inserts on the rear, driver, passenger side mounts before and it was well worth the money.
I have Innovative’s 95a shore hardness urethane mounts. They are VVEEERRRRYYYYYY stiff. So unless you are like me and dont mind everything vibrating or your head unit skipping your cd’s then get a softer mount. But I recommend Innovative Mounts 100%
alright thanks for all the help guys. I’m going to go with the innovative 75a mounts
Good choice :rockon:
