While Driving, I experience "CLICK/CLACK" sounds comming from the front.
Whenever i accelerate, or give gas after shifting… a click/clack noise seems to appear.
also my dot3 brake fluid leaks from the passenger side axle i believe? im not sure what it is called please excuse my lack of knowledge here…
So the problem is whenever i accelerate or finish shifting gears after giving gas it makes a clicking clacking sound
is there a problem with the axle or transmission? please get back to me
thanks for your help.
-DA
[QUOTE=Damado93;2158839]Whenever i accelerate, or give gas after shifting… a click/clack noise seems to appear.
-DA[/QUOTE]
the brake fluid is on the drivers side not passenger side. How is the shifting? Sounds like transmission oil to me if its thin and not thick like grease. It could be an axle seal that’s bad and what your hearing is the transmission gears slamming from lack of lubrication .
I know the brake fluid is on the drivers side, but the fluid is leaking from the passenger side somewhere
shifting works on a dime… only after i shift and give gas is when i hear the click clack sound like something is loose or not tightened enough… it scares me because i’'ve never heard it before
where could i find the transmission oil?
and possibly the axle IS bad… because everymorning i see a tiny puddle of the brake fluid FROM the passenger side either coming from the axle or somewhere else on the passenger side
thanks for you help and thoughts !!
-DA
I would be willing to bet it is the CV joint on one of your axles. This is the classic symptom. It will soon start to click while going around turns of one direction, but not necessarily the other.
It is easiest to just replace the whole axle.
FYI: Searching is your friend.
EDIT: You also need to find and fix that leak. You fill your transmission fluid with Honda MTF (Manual Transmission Fluid) in a hole in the transmission. Pick up a manual for your car.
Also, you can have brake fluid leak from about 90 bajillion different places. To say it isn’t brake fluid because it is on the passenger side of the car is just asinine.
[QUOTE=buymysoul;2159476]To say it isn’t brake fluid because it is on the passenger side of the car is just asinine.[/QUOTE] Needless to say but, if OP has ABS then he has a brake fluid reservoir on the passenger side.
