will g3 seats work on a g2?
hey- i was wondering if anyone had any info about whether or not g3 integra seats will work on a g2 integra… (both the front and back ones) if they work, how? thanks,
steve
I would assume so. Alot of people swap 94+ gsr leather seats into their g2’s. Search for ‘integra leather’ on ebay - you should find some.
derrick m.
i have no idea if the rears fit, i’d guess they don’t.
the fronts don’t fit either. only 3 of the 4 bolts on the bottom line up with how it should be. Plus you’ll have to rig something up to enable you to use the auto seatbelts–but this wouldn’t be too hard.
My wife has a 97 integra and the seats do not fit in my 1991 integra. The brackets are wider on the g3 front seats than the g2 seats. Also the g3 seat is a lot taller. so if you did figure a way to bolt the seat down in your g2, you’ll be about two inches taller than the previous seat.
no idea about the back seat.
good luck.
i have 98 ITR seats in my 90 integ, they do fit, but i was only able to use 3 bolts insead of 4. gyea and they do sit hella higher, but it dosent matter, cause i have ITR seats…:stuck_out_tongue: :wink:
REAR SEATS DO NOT FIT IN G2 INTEGS
I dunno why you guys say it doesn’t fit, my buddy had 96 GSR leather in his G2…front and back…you can make them fit with some slight mods.
Can you show us some pics?? I’d be interested. Either that or ask him what mods he had to do?? I’d assume that the G3 seats would show a gap on the sides when mounted in the rear but I could be wrong… This would be a good place to build a fiberglass enclosure perhaps…
Andrew.
yeah, I wanna see some pics too… if anyone has any ideas/methods to installing g3 seats in a g2. post them here…
thanks
steve
I have g3 gsr leather in my g2 integ. Fronts needed some new holes on the one side and the seatbelt didn’t work I had to put in a new one. Oh and the backs dont fit at all, if you want them to fold down you have to weld brackets and stuff, so as of right now I have GSR leather in the front and cloth in the back, I plan to take out the GSR leather and sell it and put in recarco seats in the front (tomcats maybe?) and so if your interested in slightly used but not abused black leather GSR seats let me know. =)
Chado
hey- what did you do to make the seatbelt work? did you do a 5 point instead? also, is the seat wobbly with only 3 bolts? id expect it to rock back and forth while u drive and stuff… thanks
steve
the seats wont wobble at all…and the seat belts juss bolt right on to were the original seat belts were…
well on the sides of the orignal seats theres bolts that stick out so u can bold the autoseatbelt box thingy to it… how do u deal with that
The seats now have 4 bolts (drilled and bolted remember) and I have 4 seat belt buckles, one on each seat, and one bolted to the floor (the one I use) Not my preferred way of doing things but thats how it was when I got car. I’d prefer some racing seats and 4 point harnesses.
ok check this out…u know where the seatbelts for the g3 integ’s r, well juss unbolt that, then bolt on ur g2 auto seatbelts…juss bolts right on…noooo problem, wait unless 98 ITR seats r diff than g3 seats…i dont think theyre diff…shouldnt be a problem…
