wiring one pieces?
i just recieved my one piece’s and was wondering which wire goes where? teg tips dosnt help that much. can someone tell me wire for wire where they go? thanks i appreciate it.
Should be color coordinated.
gee sounds like your all riced out huh? lol:D
thanks
Colors
Exactly. The wires on the JDM’s are the same color as the wiring from your old harness. Just splice them together and you’re set.
if yours does happen to be different its still easy. the signal is the same. the foglight is just a black ground and whatever 12v. if neither is black you can use a voltmeter or just test it with a bulb or something. the headlight ground is the left prong. the top is the low beam, and right is the high beam i believe. if not, jsut switch the top and right.
fyi the fog is the middle one. its just not actually behind the fog i guess for access reasons archivethis
Re: Colors
I’d recommend soldering all the wires together, but that is just what i learned when installing my one pieces…
and one other thing i learned, seal them up with clear silicone, no matter what, when you get them, before you install them…
ya i forgot about sealing. well i thought about it but was too lazy heh. im sure ill pay for it later. oh and does this include heating and removing the old seal or just adding around the trim?
well, if you’re opening the pre-existant seal to take out the yellow fog lens, then obviously you must seal it back up when u put it all back together, but if u plan to just pop them in once u get them, don’t think twice about just sealing them with clear silicone as they are…doesnt take too long, just do it right so u never have probs with them in the future:)
