HELP i had my reverse indiglo gauges installed and the guy didn’t take the 2 bulbs above cluster out. Which wire(s) do i need to cut to disable these lights ? Thanks for any help.
P.S. the guy wont open it back up w/o pay 45$/hr. And i could do it myself but i dont want to take it apart.
You have to remove the bezel to get to the wires/ bulbs. zOn top of the cluster there is a white wire you bcan unplug it if you can get to the back of the cluster. Or you can pull out the bulbs. I think that you have to remove the metal brackets to get to the bulbs.
grr did you get the ones with the red marks at every number? i ordered those but the bastid sent me the regular ones instead. ya you can just yank the bulb out after you remove the cluster. i forgot about that and left it in. you might not even have to disconnect teh speedo and other cables if you can get your hand back there. its on the top, slightly off center to the right. you twist it about a quarter turn (i forget which direction) and yank it back
