why risk NOT having it? if not i wouldn’t rev past 7500 IMO. some here have been lucky and not floated a valve… yet. is your bottom end built? ( ARP rod bolts, shot peened rods at least?)
i would… better safe then sorry. but like said… some people have been lucky… and that’s with boost too. up to u bro.
if yer bottom end is resleeved… u shoud be okay… but damn might as well right since u did all that other stuff? hope yer valvetrain can take the upper RPM abuse too.
I’ve got a built LS/VTEC and it was the first thing i bought in the build well woth it…it’s not very big but it does a whole lot…stabalizes your crank while reving to 8g’s!
Did you have the mains and girdle doweled? Do a search on www.honda-tech.com on the girdle and on member FFgeoff. I have the girdle and I dont know if I want use it or not now.
Originally posted by Integ5150
[B]why risk NOT having it? if not i wouldn’t rev past 7500 IMO. some here have been lucky and not floated a valve… yet. is your bottom end built? ( ARP rod bolts, shot peened rods at least?)
i would… better safe then sorry. but like said… some people have been lucky… and that’s with boost too. up to u bro. [/B]
well I guess I’ve been lucky for close to 30,000 miles then- stock ls rods new main bearings at time of conversion and ITR pistons. Normally revv to 7800-8000 at the highest cause my setup doesnt produce power after that
