zex
if anyone is running a zex kit off wot could you please post up here which wire you connect it to on the tps sensor red/blue, yellow or green/white
thanks
ttt
if someone could respond it would help out alot
green white
the TPS wire is the green white wire coming off the back of the throttle body? also, to those who have an aem intake with the zex kit…how do you run the vacuum line from the zex management unit into the intake? did you drill a hole? there must be an easier way. Can you leave the other zex vacuum line on the FPR all the time, does the stock vacuum line do anything? thanks for your help
