1/4 Mile Calculator
http://www.exoticcarsite.com/1-4_mile_calculator.htm
Just thought it would be usefull to those askin the question “How fast would i run?”
and remember gear ratios, elevation, track temp, ect all play a part. but it is pretty good.
here is another one
[thread jack]calculator [/thread jack]
damn thing said i should run a 14.7… :bawl: Im only running a 14.9
both calculators say i should be in the mid-12s…not bad.
the second one seems alittile more accurate you also have to add your own weight to the weight of the car, so that may be affectig some peoples results, said im runnig 14.2’s which is proubly right
yeah it says my crx should run 14.5 and my best was 14.9 spining tires so with new tires i should run better just gotta wait till the next track day.
and maybe new suspension.
well… it says… i should be running 16.1… and i’m running 15.5…
NO vtec B16A Tranny… and MY ECU is tuned
It says I should be running 9’s. 9.9 to be exact
The other said a 9.3
not a good calculator,
its not saying horsepower to the wheels, or flywheel.
there are many other better ones if u search.
:read: not a good calculator,
no where to add trq? isnt that a big factor also?
