1 peice light inside crack .......advise?
what should i do to fix this the part where the bulb goes is cracked and the bulb wont stay on is it fixable ? the scew that holds it down wont stop screwing anymore well look at the picture lmk what can i do? thanks
anybody:think:
Id try molding it up with JBweld
i’d say find a replacement for that piece.
what side is that, I have the passenger side for parts.
that is passenger side
I think the reflector lens is broke though, but the back piece you need is good, but theres no way to take off unless you just cut it and glue it if you want a legit piece, thats a lot of work. what I would do is just use something to hold it down, theres many things you can use.
nevermine the cutting, cause I just took another look at your situation, it won’t work like that
to hold the bulb down or the whole peice from the inside?
just a tip on the front part, the back is all good though I think, I got to check on that.
what i did for now i put a drop of gorilla glue on the 3 lil tabs on the bulb and put it in there idk if u can zoom in to the picture but u can see wer the 3 little gaps for the bulb tabs used to be i messed up and put it upside down now my high beam shines down
can you see it?
did you glue the h4h bulb in there, if you did, just take it off and put it right.
the pic looks the same as the top one. I think your better off just looking for a replacement. there should be alot of peeps with parts, I just replaced a whole driverside. I had the housings and posted up a wtb lens. I end up getting a non cracked len and the complete reflectors for a good price.
if i try puting it in right one of the tabs will be flying because the part where it supposed to sit is the broken part and it glued on really good i picked up the whole headlight from the bulb after i glued it on (gorrilla glue)
yeah, it would be flying all over the place since it doesn’t have its place to be held in. like i said i got an extra piece if you want just pay shipping, I think I have the broken pieces with it too. all you have to do is glue em.
you have a picture of it?
you think it would fit inside a usps priority box?
nope, I’ll try to get a pic, if I do, I’ll post it up on here, but right now I’m bout to log off.
k thanks man
