(15 NOV 2026) What are you doing with your Integra this week?
Found oil in 2 cylinders. Appears to be valve cover gasket failure. I’m going to put on a B20 cover to prepare for the eventual installation of the DigiDizzy unit. I need to strip the valve cover and design a plug for the B20 PCV hole.
Anyone have any leads on some RacingHart CP-035’s in 15x7? New unobtainable part that I want lol
all 4 spark plugs were really difficult to remove. I purchased a spark plug tap so I’m hoping to clean out the threads. This is so weird.
When I first got my car I thought the plugs were going to take some cylinder head out with them, the way they felt coming out. thankfully that didn’t happen.
I had the same problem with one cylinder in my civic. I bet the oil sitting in the cylinder has permeated the threads and gunked them up.
(Possible unnecessary information below)
Be gentle with the tap and work it in and out bit by bit. Don’t try and clean out all the threads in one go as that might put excess pressure on the threads. As soon as you feel a bit too much resistance, back the tap out and clean it off. I also put a bit of oil/lubricant on the tap and clean it off after every insertion. Just take your time with it.
Yup I believe you have to grease it up, turn a few threads, remove, clean and then repeat. I appreciate the warning!!
:face_exhaling:
It’s stressful for sure, the thing is to remind yourself what you’re doing, and taking your time. I will need to have the same state of mind when I try to repair my ECU. :downcast_face_with_sweat:
Best of luck.
I no longer have the steady hands to solder :frowning:
I may not have them either. Ill get back to you once I either kill or fix my ECU :joy: Hopefully your situation with the intermittent start issue isnt also the ECU.
The ECU in this teg was already replaced. So I’m not sure.
Hopefully this spark plug / valve cover remedy works and I can focus on that again.
Ahh. Hopefully something simpler, then.
And I still intend to buy one of the manga posters, (and possibly a couple 3d printed goodies) just a rough time for expenses right now. My cars have lost the will to live but I won’t let them die on me.
Printed a valve cover, then made an edit to the next one so it can hold business cards:
BWAHAHAAH that is AWESOME!
