150k service checks?
what all would you do to your car at 150k miles, i’ve put only the last 20k miles on but the car is in good condition other than the freaking tailpipe that fell off last night leaving one tiny off-center tailpipe sticking out…
im guessing from the helms
check valve clearance
check fuel pipes, hoses, and connections
check distributer, spark plug wires and plugs
check alt drive belt
check cooling hoses and connections
replace coolant
check timing belt
check exhaust
replace tranny fluid, oil/oil filter
check clutch release arm
check brakes, lines and adjust parking brake
replace brake fluid
check alighnment
i just had the rack replaced so im guessing thats okay
is there anything im missing
im doing my suspension this summer so im putting off the brakes and alignment and all that
the guy i got it from had the clutch replaced recently before i bought the car so should i just wait until the clutch feels different or how ofter do you check yours?
Yeah if the clutch feels the same don’t worry about it until something changes especially if you said it was replaced recently. If it the pedal feels lighter or the friction point changes, or you have trouble getting into gear then worry about it. Otherwise your list sounds good :up:
