I was wondering if 17" rims 40mm bs with 205/40/17 tires will fit and not scrub if you do not lower the car?
I believe they would. You’ll look like a monster truck if you do, but whatever floats your boat haha. It’s hard to fit 17’s under a G2 and make it look good. Only a few have succeeded
theres lots people running 17’,the right rims and off set and camber could look great.
That’s all I’ve owned on my DA is 17’s. Sure I would like to go 16" but never found a set of rims that I liked that went over 15".
All it is is a slight drop, Skunk2 Coilovers with kYB Gr2 (bad mistake on the gr2’s blew a year later) The lip kit helps out a lot to keep it looking low. But for the most part, no body noticed they were 17’s. All it takes is a cleanly done drop.
