17x10 et)+20 17x8.5 et+30 staggered setup??
anyone on here with this setup if so what size tires to go with that arent to stretched/skinny
also post pics thanks…
http://www.ebay.com/itm/17X8-5-17x10-STR-606-RS-STYLE-4x100-GOLD-WHEEL-FIT-VW-GOLF-JETTA-CABRIO-CORRADO-/130979024622?pt=Motors_Car_Truck_Wheels&hash=item1e7ef54eee&vxp=mtr#ht_10081wt_894
http://www.ebay.com/itm/17X10-STR-606-RS-STYLE-4X100-4X114-3-20-GUN-METAL-MACHINED-RIM-FIT-HONDA-SCION-/130938613950?pt=Motors_Car_Truck_Wheels&hash=item1e7c8cb0be&vxp=mtr#ht_10178wt_894
FITMENT : Some vehicles may require additional modifications
4x100 bolt pattern
Ideal Aggressive Flush fitments:
1986-2001 Acura Integra
1984-1991 BMW 3 Series (E30)
2004-2008 Chevrolet Aveo
1990-2005 Honda Civic
1992-1997 Honda Del Sol
1988-1991 Honda CRX
2007-2011 Honda Fit
1989-2004 Mazda Miata
2004-2007 Scion xA
2004-2007 Scion xB
1986-1991 Toyota Celica
1985-1989 Toyota MR2
2000-2005 Toyota MR2 Spyder
1988-2002 Toyota Corolla
1983-1997 Toyota Tercel
2007-2010 Toyota Yaris
1997-2003 Volkswagen Cabrio
1989-1992 Volkswagen Corrado
1985-1998 Volkswagen Golf 4 cyl.
1981-1998 Volkswagen Jetta 4 cyl.
thinking about getting these in silver or gunmetal mesh for my sedan since im bored of these enkei’s
I am interested to see a staggered setup on an Integra, especially one that is two inches of difference. I don’t know if I would like it…I hope someone post pics though so I can change my mind
always done in the euro world
http://www.r3vlimited.com/board/showthread.php?t=271071
17x10 +20/30?
Hope you like rolling/chopping fenders.
the fact that hes even asking abouut trying to make a set up like that fit shows he doesnt care…
he just wants to be able to say he got it to fit. im sure if he had to delete his front fenders, he would be just fine with that.
[QUOTE=unified112;2307277]17x10 +20/30?
Hope you like rolling/chopping fenders.[/QUOTE]
which is why i made this post. the front will not be a problem.
ive seen many honda’s on google image with 15x10 or 16x10’s but no info on there offsets? besides that my rear arches will be getting pulled and rolled since i have to take care of some minor paint issues.
[QUOTE=DA_all_day;2307281]the fact that hes even asking abouut trying to make a set up like that fit shows he doesnt care…
he just wants to be able to say he got it to fit. im sure if he had to delete his front fenders, he would be just fine with that.[/QUOTE]
dude go away!! i notice u just come on my ads to start crap!
you got me… the jig is up
:up:
reported. troll elsewhere and get a life.
While i don’t have that setup i do have some experience fitting different sizes of wheels and tires that probably shouldn’t be on a da.
Width is no big deal if you’re ready to hack up body work although with the right offsets you’d be surprised by what can fit underneath the stock bodywork. NOT talking about hellaflush camber bullshit.
Front offset should be minimum of +36 to clear the knuckle and rear should be something like 20-25(dont remember exactly) So you’re on the right track with those wheels, they should fit underneath stock body work (stock body work thats been rolled and probably pulled a little too) with a 23-24 inch tall tire.
Now since you’re talking about 17’s it gets a little more complicated. I have not run 17’s but have run a tall tire on a 16. It was 25 inches tall with an offset of around +20 and the issues i ran into with that was suspension travel being limited by tire clearance and not geometry/bumpstops/chassis points. Kinda sucks when you’re loosing something like a inch of travel because of tire size. There is no solution to this unless you’re great at fabrication and welding because the problem up front is the frame rail above the wheel. You can cut/bend/weld the seam out of the way so you don’t chop up a tire but that only gets you a little more clearance. Ideally you would have to cut and box that part of the frame out of the way. Out back the issue is the metal inner fender liner. Wtv, that can be chopped out of the way.
Is this for a crazy looking street car or do you plan on driving it? Cuz the ride height won’t be so hot if you plan on attending a hpde.
Keep in mind the offset mentioned was for a 15x9. You could probably run a more positive offset in the rear with a 17 since a 15 runs into the rta uca mount point first. Maybe the same for the front since the knuckle gives a larger diameter more room just watch out for the tire and upper balljoint clearance.
thanks on the help, still waiting to see if they offer other offsets. the wheels thats on the car now is 15x8 et25
forget about safety and function. stretch and poke with huge -camber is the way to go.:shrug:
read the ad !
