1990 Gauge Cluster Pin Out
Hi there.
Im looking for the pinout or wiring diagram for a 1990 Gauge Cluster.
I picked one up froma wrecker because i like the style and set up much more than my stock crx setup.
So far ive been unable to find any information on these clusters, Info however on the itr and gsr is abundant. Is the wiring similar?
Any help would be great.
Thanks a lot.
-Bobby
PIN Wire Color Wire Function
A1 Yellow/Red Seat Belt Reminder Light
A2 Green/Red Parking Brake Switch Light
A3 Green/Black Hatch Open Indicator Light
A4 Green/Red Low Fuel Indicator Light
A5 Yellow/White Fuel Gauge
A6 Yellow/Red ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7 Red Gauge Lights, Dash Light Dim
A8 Empty
A9 Red/Black Gauge Lights
A10 Green/Yellow Right Turn Signal Indicator
B1 Green/Blue Left Turn Signal Indicator
B2 Red/Blue High Beam Indicator
B3 Blue/Red ABS Indicator Light
B4 Blue Tachometer
B5 Green/Red Door Open Indicator Light
B6 Yellow/Green Engine Coolant Temp Gauge
B7 Black Ground
B8 Yellow Ignition Power
B9 Green/Orange Malfunction Indicator (Ck Eng.) Light
B10 Black/Yellow Charging Sysem
B11 White/Blue Charging System (Battery) Light
B12 Yellow/Red Low Engine Oil Pressure Light
C1 Red Cruise Control Unit
C2 Red/Black Gauge Lights - Cruise Control Dimming Circuit
C3 Empty
C4 Empty
C5 Black Cruise Control Ground
C6 Empty
C7 Yellow Ignition Power for Cruise Control Unit
ohh thats great, thank you very much
i followed the traces but there was some i was unsure of, you fixed that for me, thank you very much once again :slight_smile:
