What’s up guys, I picked up another DA, and this one is here to stay.
It has no rust, has 240,000 miles, from California! Still had the original clutch in it even.
I will have to add pictures when I get home, currently in Nebraska for work.
Anyways onto the h series! Picked up an h22a4 long block. Been thinking of a few different setups for this h build. I plan on using it for auto cross, so a huge amount of power is not necessary. Anyways I think I have found a setup I am happy with.
H22A4 Block - sleeved to 88mm
K24 Crankshaft from rosko racing - 99mm stroke
K20 Forged rods - undecided
H22 Type s pistons (88mm)
H22A4 Head
Flat valves
Undecided on cams
dual valve springs
Ending up with a compression ratio of 12.5:1
Plan on running e85
Tell me what you think! Help on deciding cams would appreciated.
