1991 integra Ls problems
I just bought a 91 acura integra and it has a few problems I’m trying to solve any help would b greatly appreciated 1st the car jerks when accelerating 2nd there’s a very noticeable vibration when at a complete stop and only when at a stop 3rd and lastly my turn signals don’t work correctly when i use left turn signals the one on the right also works at the same time as the left one
Thank you
The turn signal issue is conmon. Happened in mine an it can be the actual turn signal switch. An what i would do is jack up the front end an grab at 3o clock position an 9o clock an see if you have major play. An also 12 o clock position an 6 o clock. My integgy had this issue an ended up being a bad upper control arm (when i would hit the brakes it would pull me super hard due to the control arm changing camber). So run a shake down on the tires in the air. An it will tell you whats wrong. Another way you could check is go to les swhab you can have them shake it down(if you dont like doing it yourself) an most of the time theyll tell you whats wrong for free!
