1992 integra gsr with swaped jdm b18c gsr
I got the motor in and running but idk were to connect all my water and air hoses it’s all different and idk about the throttle cable either it doesn’t look like it will work with the b18c throttle body does anyone have any diagrams or good pictures
Hopefully you have it running by now lol, but…
You’re right the throttle is different on the JDM. I put one in a 92 USDM LS and I believe I had to use a 90 throttle cable. Even then it loops weird and I tie it down with a fat zip tie, probably because with JDM the driver is in the “passenger” seat.
Don’t know about the coolant hose issue, that was fine for me. The intake is also different - I had to have a hose shop fab-up some longer fuel lines to get around the intake, and am running after-market intake, stock did not fit.
